How can we expand maximum limit of DSS Search function API? Under DSS Reference Tree 'Equity Search', It says 'Search for equities (common, preferred, etc.), indices, exchange warrants, equity options, open funds, etc. Note, the paging skip token does not work. The search will return 500 results (page size) by default. If your result set is larger than this, you can increase the page size in the request or narrow your search criteria.' How can we increase the result to maximum number i.e. 5,000 instruments through REST API?
