I would like to know if there is a way (testing feed or application) to verify we properly handle various use-case in our ETA consumer application. More specifically, some use case that might happen when a stream stops working with an RSSL_MC_STATUS.
I have read https://community.developers.refinitiv.com/questions/7417/how-can-we-test-the-ema-consumer-application.html, however I would like to know if the situation has changed in the 2 years since. The solution proposed seems to be aimed at performance monitoring rather than testing if the application handle various problematic situations correctly.
For instance, we once receive an stream closed when a instrument was delisted, and this was not something we previously tested.
Is there a way to test an ETA consumer application ?
Thank you,
Didier
