Can we filter response, like the filter used in AuditEvents.
We want to filter the response and only get the match with "matchStrength": "EXACT"
Unfortunately, we do not have that functionality at our end as Seq-5b:Get Screening results is a get request which will send a JSON response back to your systems when hit, you need to have an extracting mechanism at your end when you configure your systems with World-Check One which will enable you to extract fields or results associated with the tag "matchStrength": "EXACT" from the Seq-5b JSON response .
Let me know if you need further details on this!
Thanks,
Mehran Khan
API Technical Consultant
