Is there a tool that I can record data from TREP ads server and replay the data to TREP infra for testing?
I am looking for a tool that I can use to record market data and replay the data in our TREP infra for our testing. We usually use rmdstestclient to record data. Would you please advise if we can use the same command for data replay? And what is the parameter we should use? I am looking for something like a tool that could record data , then replay at faster/slower rates
elektronrefinitiv-realtimetrepdatainfrastructure
23k 22 9 14
Hello @nikita.ou,
First, confirm that your recording contains updateMsgs, and not just refreshMsg
If it does, next try
sink_driven_src -S ACTIV -C 100000 -E rssl -N 14003 -U 1 -K -Q
/reuters/ads/demo/active.out
I think you may be confusing replay with "-l", and instead of replaying the updates from your capture file, the tool is trying to generate an update of length 1, which may not be working
I prefer rmdstestclient with "-v" to rsslSinkApp, but both should work.
Thanks Zaya, the recording doesn't contains updateMsg. I try your command. it works now. Thank you so much for your help!
Hi @zoya.farberov . it works when I use the rsslSinkApp, but when our application team try to connect, i get the below error msg.
In readFromSession() calling rsslInitChannel() Session Inactive fd=4 <<Impl/ripcsrvr.c:3335> Error: 1007 Unknown connection type.
In their connection config, they use RSSL too. Would you please advise what might be the root cause? Thanks
Hi @nikita.ou ,
This is why I like to be explicite and use both "–ct rssl" on record and "-E rssl" on replay.
This ensures you are recording and replaying RSSL.
If the downstream client uses RSSL (?) it should be able to consume.
Confirm if downstream client expects RSSL or SSL. Does it regularly connect on 14002? or on 8101 (SSL port).
I did use -cr rssl on record and -E rssl on replay. The downstream app uses RSSL too. Below is their config. I replay the data on port 14003 as we have the Prod feed available on port 14002 in the same server.
\Connections\reutnjads\connectionType = "RSSL"
\Connections\reutnjads\rsslPort = "14003"
Downstream app tries to connect to normal live market data. It works. The issue only happened when they connects to the replay data. I can see they connect to that port but the subscriptions doesn't work.
Below is msg that the downstream app gets in their log
Service: ACTIV
Item: SPY.
StreamState: Open
DataState: Suspect
StatusCode: None
Source unavailable... will recover when source is up
Hi @nikita.ou
From the error above message- they are connecting.
They are failing to consume item SPY from source ACTIV
I would verify with a standard client. Try testing service ACTIV item SPY with rmdstestclient.
If rmdstestclient is able to consume an item from service via user, then a custom client should be able to do the same.
23k 22 9 14
I would say that there are two prevalent options:
1. Infra tools package that includes rmdstestclient also includes sink_driven_src tool. Rmdstestclient can be used to record data into a file, while sink_driven_src can be used to replay it. Document "Demo Tools" that is included with the package goes over the functionality, in brief. Each tool displays help on it's command line switches. One can replay/simulate data at specified rates, i.e. msg/sec.
2. To cover more advanced replay requirements, for example, GUI-driven, drill-in and selection, replay at times the original speed, modifications on the fly, other, one can use ReplayService tool. For more information please contact TR sales.
Thanks Zoya,
I record the data by using "nohup ./rmdstestclient -S ACTIV -h localhost -p 14002 -f ACTIV.ric -u radmin -ct rssl -m -X -d 3 -micro >Activ.out &" and try to play back the data by using " ./sink_driven_src -S ACTIV -K -N localhost -Q /reuters/ads/demo/Activ.out -c -b -I 10"
But i am getting the following:
Error: Unexpected Exception during XML parsing, possibly file is not found or corrupt
Error rsslBind(): <Impl/ripcsrvr.c:1381> Error: 1004 ripcGetServByName() failed. Port number is incorrect. (0)
Would you please advise how I can resolve this?
Hello @nikita.ou ,
Inspect the capture file. Is it created? Does it look to be a well-structured and complete xml file?
I would try
-of active.out -l active.out.log
instead of ">"
then you can also review the log looking for errors
cusersnouonedrive-macquarie-groupmarket-datathomso.txtThe data capture seems to be correct to me. I have attached it for your reference.
Below is the msg I get when I run sink_driven_src this time
Initialized RSSL library.
GLOBAL update order enabled.
Item template & Update template will not be used.
Loaded refresh: 3 updates: 3486
Enter Command (help): .
Loaded pkts: 0 items: 2 images: 2 image_length: 0 unsol images: 0 updates: 3486 update_length: 0 memory (MB): 0.827613
Hi @nikita.ou,
Same here.
Try this replay
This is my default replaying command line, with your service and recording name substituted.
Let me know how it works for you.
@zoya.farberov thanks. I started the data replay by using
" ./sink_driven_src -S ACTIV -K -N 14003 -Q /reuters/ads/demo/active.out -c -b -l 1" then
use "./rsslSinkApp -h mdshkdev35 -p 14003 -U radmin" to subscript the data.
However i only get an image update at the subscription, there is no update of the RIC coming after that. Would you please advise?
