How to use use the websocket API to request more then one instrument
We are using the WebSocket API https://api.edp.thomsonreuters.com/streaming/pricing/v1/
We haven’t find a way to request more than one instrument at the time and get a snapshot request. Our understanding at the moment is that we should start the stream for a certain instrument, get the snapshot data and terminate the stream. Is it an option to request more than once instruments in the same query and how do we do it?
The nest question is weather we can start more than one stream in the same time from one virtual machine?
treprdp-apiwebsocketsrrto
9.7k 49 38 60
Hi @mila.zaharinova,
As outlined within the WebSocket API documentation, you can specify the instrument within the JSON request as an array.
Regarding the # of streams, there should be no issue to open more than one stream simultaneously.
