How to pass additional parameters to csv file for Batch Uploading?
When creating a csv with several hundred tickets for batch processing, I want the file to contain all necessary information to minimize the # of manual modifications required after uploading the csv file into REDI or PT for batch release.
Certain order types require additional parameters:
(e.g. VWAP, TWAP, EDGX <inside limit bid allowance = 0.30>, smart route 'xyz' <urgency: passive/aggressive/normal>, etc..)
The code snippets don't include fields for these additional arguments to passed in:
ptOrder.Symbol = "IBM";
ptOrder.Side = "Sell";
ptOrder.Quantity = 7;
ptOrder.Exchange = "*ticket"; //PT is a bunch of tickets
ptOrder.Price = 143.71
ptOrder.Account = "YourREDIAccount";
ptOrder.SetTFUser("YourREDIUserId");
ptOrder.SetTFList("TestList1");
ptOrder.Warning = false; //Disable the pop-up warning for invalid limit price success = ptOrder.Submit(ref err);
eikon-com-apiredi-apicsvportfolio-trader
Found the answer in the REDI API Specification Ver 2.0, which I've included here. Is there a difference between REDI API Specification Ver 2.0 and Ver 1.0 for REDIplus?
When a ticket is generated with "current date" passed into the Order.Ticket, will all tickets with the same value go to REDI as staged/parked orders? (The goal being to have the option to either batch release all tickets, partial batch release, or individually...)
h.Order.Ticket = "<current date>"
‘ Create a new order object
Dim hOrder As New Order
‘ Set order attributes to the order object
hOrder.symbol = “ZVZZT”
hOrder.Side = “Buy”
hOrder.Quantity = “100”
hOrder.Exchange = “DEMO ALGO”
‘ Set algo strategy
hOrder.PriceType = “VWAP DEMO”
hOrder.Price = 0.01
hOrder.TIF = “Day”
hOrder.Account = “00999900”
hOrder.Ticket = “Bypass”
‘ Set custom algo fields
hOrder.SetNewVariable “(MB) Start Time”, “155500”
hOrder.SetNewVariable “(MB) End Time”, “160000”
hOrder.SetNewVariable “(MB) Exec Style”, “Aggressive”
Dim errStr As Variant
Dim rtnVal As Variant
‘ Send order object to REDI
rtnVal = hOrder.Submit(errStr)
Debug.Print errStr
Version 2.0 (Dec 2017) is the latest version of the REDI API documentation.
hOrder.Ticket = "Bypass" will send orders directly from the sheet to REDI as live orders.
hOrder.Ticket = "Stage" will send staged orders to REDI, which then need to be released manually in REDI. You can release either one by one or as a batch.
To confirm, do you want the ability to review/release the orders in REDI once they've been created from your program? If so, then "Stage" may be what you need.
-Brian
Yes, thanks.
