Java Client for TR Chart
I try to call the chart service with java, but get invalid child element error. I have implemented the java client using the C# example and comparing to the xml request I see in the API page (https://www.trkd.thomsonreuters.com/SupportSite/TestApi/Op?svc=Charts_1&op=GetChart_2).
Please find the attached TR-request from the api page (getchart-request-2-troriginal.txt) and the request generated from our java-client (trchartrequest-bwside.txt). The error that appears is as follows:
de.byteworx.reuters.model.charts.ICharts1ICharts1HttpsAndRKDTokenGetChart2ClientErrorReferenceFaultMessage: The element 'StandardTemplate' in namespace 'http://metastock.com/imageserver/financial' has invalid child element 'ShowNonTradedPeriods' in namespace 'http://metastock.com/imageserver/financial'. List of possible elements expected: 'YAxisTitles' in namespace 'http://metastock.com/imageserver/financial'.
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
	at com.sun.xml.internal.ws.fault.SOAPFaultBuilder.createException(SOAPFaultBuilder.java:135)
	at com.sun.xml.internal.ws.client.sei.StubHandler.readResponse(StubHandler.java:238)
	at com.sun.xml.internal.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:189)
	at com.sun.xml.internal.ws.db.DatabindingImpl.deserializeResponse(DatabindingImpl.java:276)
	at com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:104)
	at com.sun.xml.internal.ws.client.sei.SyncMethodHandler.invoke(SyncMethodHandler.java:77)
	at com.sun.xml.internal.ws.client.sei.SEIStub.invoke(SEIStub.java:147)
	at com.sun.proxy.$Proxy356.getChart2(Unknown Source)
Please have a look and give me any hints.
Thanks,
javarkd-apirkd
Noticed error in the Request.
This request clearly has missing non-optional elements, according to the TRKD schema...
TRKD shcema xsd relevant to this bit., imported from wsdl is here...
http://api.trkd.thomsonreuters.com/schemas/Charts/ChartsFINancial.xsd
Important Notes:
When its mentioned as sequence ,should provide the request as in same order and should not skip any non optional elements according to the schema.This is the root cause for this error.
Thank you!
