Handshake failed: "Forbidden: No session"
I'm following the Side by Side Integration API Quick Start.
  • I have Eikon running, I'm logged in
  • I have generated app key, with "Side by Side API" type
  • ping was successful
  • but the handshake request:
    "command": "handshake",
    "productId": "xxx",
    "appKey": "yyy"
fails with 403 status and message "Forbidden: No session". Eikon shows no prompt.
Any idea what am I doing wrong?
Thanks!
side-by-side-apisessionhandshake
9.7k 49 38 60
Hi @petr.doubek,
I just went through the process and discovered that the instructions didn't mention to ensure JSON is selected as the format of the text. For example, ensure the following is selected:
Let us know if this helps.
thanks.
Thanks, that was it! Actually it is mentioned ("Ensure raw data is selected with JSON"), I overlooked it as it isn't in bold font as the other options that have to be set :-)
One change I had to make to the message: ProductId -> productId
Hi @petr.doubek,
I also overlooked this. However, I updated the quick start so it was a little more obvious.
