Disable TREP authentication in ADS 3.2
I’m using an ADS POP trep3.2.1.L1.B1
This is an extract of my configuration file:
! DACS Parameters
*ads*dacs*featureEnabled : True
*ads*dacs*fileDirectory : ./
*ads*dacs*fileSize : 6000
*ads*dacs*logFlushInterval : 20
*ads*dacs*connectRetryInterval : 10
*ads*dacs*usageLoggingLevel: External
*ads*dacs*usageFileName : DACS_usage.log
*ads*disconnectDacsDown : False
*ads*refuseConnectionsDacsDown : False
*ads*softwareStatsReportTime :
!!! DACS Multi-Connect
*ads*dacs*doMultiConnect : False
*ads*dacs*domainList : DACS_CHICAGO, DACS_NEW_YORK
*ads*dacs*DACS_CHICAGO*port : 8211
*ads*dacs*DACS_CHICAGO*forceLetterCase4Login : None
*ads*dacs*DACS_NEW_YORK*port : 9111
*ads*dacs*DACS_NEW_YORK*forceLetterCase4Login : None
!!! Authentication
*ads*authentication*tokenAuthenticationHosts :
*ads*authentication*authThreads : 1
*ads*authentication*connectTimeout : 15
*ads*authentication*compatibilityMode : allow
*ads*authentication*iauth2Trace : False
This is what the adsmon tell me: List of DACS Connection Managers
Role                    DACS Enabled    Authentication Enabled
Consumer                True            False
Publisher               True            False
It seems like the TREP authentication is disabled, which is what I want.
But if it’s disabled, then why do I have an error message:
<xxxx.sop.ads.dacs: Error: Wed Jun 27 10:11:00 2018>
Cannot enable TREP authentication. No authentication hosts defined.
<END>
I want to disable this feature, but I don't want the error message when I start my ADS.
elektronrefinitiv-realtimetrepauthenticationinfrastructureADS
You can comment all authentication configurations in the configuration file.
!!! Authentication
!*ads*authentication*tokenAuthenticationHosts :
!*ads*authentication*authThreads : 1
!*ads*authentication*connectTimeout : 15
!*ads*authentication*compatibilityMode : allow
!*ads*authentication*iauth2Trace : False
This will also disable this feature and there is no error log in the ADS log file.
Thanks a lot, it's working!
