Can I access the API with R?
I am using the Eikon API to download EoD data via Python. However, since we mainly use R, is anyone aware of a way to directly download the EoD data in R via the API?
Many thanks
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrest-apitime-series
4.6k 26 7 22
@m.kofler yep, there is a community developed api for R available here.
Thanks Zhenya! However, I still didnt manage to connect.
I was told that set_app_id has been replaced by set_app_key. Is that correct for R too, right?
In the library I get still suggested set_app_id and i get an error when i try to run the key with set_app_key ('could not find function').
I freshly downloaded EIKONAPIR a couple of days ago but it seems that I still dont have the latest Version. I downloaded from here:
install_github("ahmedmohamedali/eikonapir")
In eikonapir library you need to use set_app_id function. What exactly do you mean when you say you didn't manage to connect?
