RHistory tick python replication
I am trying to replicate the following example (excel eikon api) using the eikon python api:
=RHistory("EURUSDON=";"ASK.Timestamp;ASK.Value";"START:02-Jul-2018 END:09-Jul-2018 INTERVAL:TICK";;"CH:Fd";E12)
Since Bid/Ask is not supported for get_timeseries I try to replicate using get_data, along the lines of question 20332
Is there a possibility to obtain the bid/ask fields at tick frequency? (streaming?) fields are "Bid" and "Ask" or Primact Secact
Thank you
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonfieldstick-data
4.6k 26 7 22
@daniel.schmitt2 unfortunately, you can not get tick data using time series over fundamental data API. If you require some API to access to time series, the only option is to use RHistory API which is COM.
thank you!
Hello @daniel.schmitt2, can you please post your python code ?
What is the RIC you are looking for ? EURUSDON= is not valid for all I can see.
KR Norbert
EURRONON=
for example, sorry for the confusion
