Issuer rating
I am currently trying to work with the ADVFIL app. I want to fetch the RIC's based on a certain filterations and then fetch the issuer ratings. The process on the app is extremely slow because in cases where i get 4000 results, the app only allows you to download one page per excel download.
How can i achieve this using the python api?
Eikon Data APIs currently don't have capability to search for filings. However if you're searching for companies rather than filings, depending on your criteria set you may be able to use Equity Screener, which is available through Eikon Data APIs as well as through Eikon Excel. To see what criteria you can use in Equity Screener follow the wizard behind the Screener button in Thomson Reuters ribbon in Eikon Excel.
