Sequence for fetching sanctioned results from WC1 API
Hi Team, I need to fetch sanctioned results for an Induvidual, say Jane Doe from WC1 API. Therefore, is it necessary to make service calls as per below steps?
1.Get Group(s)
2.Create a Case of Individual/Organization/Vessel type, under above fetched Group(s),
3.Send case into asynchronous screening queues
4.Validate screening if is finished, by sending Audit events of type SCREENED_CASE.
5.Fetch results after completion of screenings
6.Fetch complete details of each profile present in above results.
world-checkworld-check-one
4.5k 4 7 8
@nishant.sharma,
The sequence which you have mentioned is correct. If you want to sort the profiles based on the sanctions, you can do so using the "category": "SANCTIONS" from the Step 5.
Note :
It is recommended to use the API call “Get my top-level groups”, so that you get the latest modified settings of the groups.
