Reusing data dictionary across connections
I'm using ETA C API in Linux.
Here are some background information on my application and information I received from Reuters tech support assigned for my project regarding the EaaS site.
  • My application will be connecting to multiple ADSs hosted at multiple EaaS sites.
  • There is a chance that data dictionaries in different EaaS sites may be different as data dictionary upgrades may be scheduled during different maintenance windows in different EaaS sites.
  • For data dictionary updates, EaaS always re-starts ADS process.
I would like to get recommendation on the following options:
1. Use one data dictionary to decode data from ADS in different data center. I’m planning to use the data dictionary downloaded from the first connections and reuse it across connections. Download data dictionary only when the ADS where I have open subscription gets restarted.
  • Would it be safe to use old dictionary in case market price updates with new FIDs arrives from other ADS connections ?
  • I see the following code accesses dictionary by offset of the FID. I’m concerned if the FID will access the array creating out of bounds exception.
dictionaryEntry =
dictionary->entriesArray[fEntry->fieldId];
  • Is there any way to skip lookup of new FIDs that are not in dictionary by checking against the size of dictionary ?
2. Download data dictionaries from all connections (provided I make connection to different data center)
  • Would it be safe to maintain per connection data dictionary , use the latest version, and update if new version is downloaded after ADS re-start ?
elektronrefinitiv-realtimeelektron-sdkrrteta-apielektron-transport-api
Yes, if the application properly handles null value returned from dictionary->entriesArray[fEntry->fieldId].
dictionary->entriesArray supports FID between -32768 and 32767. Therefore, if the verified FID is in this range, it will not be out of bounds. However, the application must verify the return value of dictionary->entriesArray[fEntry->fieldId]. If it is null, it means that the loaded data dictionary doesn't contain that FID so the application must not accessing its value.
I don't think so. You need to verify the return value of dictionary->entriesArray[fEntry->fieldId]. If it is null, you can skip decoding.
Yes, you can do it. However, instead of downloading dictionaries from all connections, you and send the dictionary requests with RDM_DICTIONARY_INFO filter to all connections.
msg.msgBase.msgKey.filter = RDM_DICTIONARY_INFO;
With this filter, the dictionary response will contain only the version of dictionary on EaaS.
<refreshMsg domainType="RSSL_DMT_DICTIONARY" streamId="3" containerType="RSSL_DT_SERIES" flags="0x168" groupId="0" dataState="RSSL_DATA_OK" streamState="RSSL_STREAM_NON_STREAMING" code="RSSL_SC_NONE" text=""  dataSize="50">
    <key  flags="0xF"  serviceId="2115" name="RWFFld" nameType="1" filter="0"/>
    <dataBody>
        <series  flags="0x2 (RSSL_SRF_HAS_SUMMARY_DATA)" countHint="0" containerType="RSSL_DT_ELEMENT_LIST">
            <summaryData>
                <elementList flags="0x8 (RSSL_ELF_HAS_STANDARD_DATA)">
                    <elementEntry name="Type" dataType="RSSL_DT_UINT" data "1"/>
                    <elementEntry name="DictionaryId" dataType="RSSL_DT_INT" data="1"/>
                    <elementEntry name="Version" dataType="RSSL_DT_ASCII_STRING" data="4.20.29"/>
                </elementList>
            </summaryData>
        </series>
    </dataBody>
</refreshMsg>
After that, you can choose the one with the newest version and then send a dictionary request with RDM_DICTIONARY_NORMAL filter to get the dictionary.
