When we requested TS1 data and decode the date of RIC EUR= using RFA C++ and TS1 decoder using below code.
time_t time = sample->getDate(); time_tm = gmtime(&time); sprintf(time_str,”%4ld/%02ld/%02ld",(long int)(1900+time_tm->tm_year),(long int)(time_tm->tm_mon+1),(long int)time_tm->tm_mday);
The result is like:
DATE,BID,OPEN,HIGH,LOW,ASK,HIGH BID,LOW BID,OPEN ASK,HIGH ASK,LOW ASK 2018/06/27,No data available 2018/06/26,1.1552,1.1646,1.1672,1.1539,1.1555,1.1672,1.1539,1.165,1.1674,1.1541 2018/06/25,1.1645,1.1702,1.172,1.1633,1.1649,1.172,1.1633,1.1706,1.1722,1.1636 2018/06/24,1.1702,1.1657,1.1713,1.1625,1.1706,1.1713,1.1625,1.1658,1.1715,1.1629 2018/06/21,1.1655,1.1602,1.1675,1.1598,1.1659,1.1675,1.1598,1.1605,1.1677,1.16 2018/06/20,1.1601,1.157,1.1633,1.1507,1.1605,1.1633,1.1507,1.1573,1.1636,1.1509
When compared this output with other services like Datascope Select, it seems the DATE is inconsistent with DSS. See the DSS data here. For example data from TS1 on 25 June appears in DSS on 26 June. Is this TS1 data issue or decoding issue?
