How to validate if a RIC code is accurate ?
When setting up RIC code to get quotes data from the API, we occasionally run into an issue because of a typo. Is there an API in TRKD that we can use to validate that the RIC is accurate - general, case sensitivity and such ?
ricsrkd-apirkd
No. Search api service should return corresponding valid RIC codes, then use those RIC codes in the calls to the quotes api service.
Thank You !
