Use the websocket API in synchronous mode
What is the best way to get a price snapshot synchronously.
What I would like:
ws.send(request)
result = ws.recv()
The problem is that I can receive different messages (ping for instance..).
Do I have to necessarily implement a logic to filter the answers ?
treprdp-apiwebsocketsrrtosynchronous
@chbailly The websocket is a connection oriented API, and there is minimal housekeeping that has to be performed - like login before making a data request, and responding to ping requests. These have to be done, regardless of request for snapshot or streaming data.
We don't have a synchronous access helper for it, but might consider providing such "ease of use library" in future. For now, please see the implementation details in the provided code samples.
I realised that I was not in snapshot mode..
So now I think I do not have to filter the answers, I am supposed to receive the answer directly, no need to filter (no ping for instance)
Thanks for your answer.
Are you saying that potentially I can receive a ping even in snapshot mode ?
The code is not straightforward.. We have to match the correct request, the error management is also made more complicated. What do we do if we do not fintd the matching request, how do we set a timeout..; This is really easy to write an incorrect code even if it looks simple.
An helper would really be a good idea imho. Sometimes, we just need to write simple and basic code. 2 lines, the send followed by the rcv...
Yes, as long as the connection is held open, ping messages are sent to asset that TCP connection is still open. This would happen regardless of snapshot or any request for data.
The websockets is a protocol specification, rather than an API, and protocol requires that application start with a login and maintain ping/pong messages.
I agree, it makes sense; thanks
Hhi - just checking to see if any decision had been made on a synchronous access helper as yet and iff there was any potential eta for it?
Many thanks
Ranjit
@ranjit.talukdar You can take a look for Websocket examples in the TR API Samples github repository - specifically the Quote Widget, which uses the TRWebsocketController. This controller sample is in Javascript and can be used as a helper object in your own implementations.
Thanks @Gurpreet but do you have anything in python?
@Gurpreet - also this looks to be for streaming data as opposed to snapshot
@ranjit.talukdar We don't have anything for python yet. I will try to produce a minimal sample and let you know.
@Gurpreet. - Hi - just wopndering if u had any luck as yet.
many thanks in advance.
Hi @ranjit.talukdar, We are working on a library. It will be a few weeks before an early beta version can be shared with community.
Hi @Gurpreet
Just wondering if the beta version of the library is ready as yet?
No, we are targeting the library to work across different platforms, and the library interface is not finalized yet.
Thanks @Gurpreet.
is there any eta you think you could share?
many thanks
Hi @ranjit.talukdar, As of now, it we are targeting Q1 2019.
Meanwhile, is there any coding help we can provide to get you going with your project?
that would be great - many thanks @Gurpreet.
