Does PROD need to have 1s delay between the API Calls to avoid 429 error?
I am using the trial version to of the World Check One API and I follow the same procedure it is mentioned in this Question:
https://community.developers.refinitiv.com/questions/24958/error-429-wc1-api.html
And I have the same issue with getting 429 response. I see that the answer mentions that between the different API Calls we should have a delay of 1 second. I wonder if that's the case only for Development or if it's the same in PROD.
world-checkworld-check-oneerror-429
4.5k 4 7 8
@evanthia.tingiri,
Its the same for the Production and Pilot Environment. The best recommended practice is to call 1 API call per second.
