TRCC test with EMA Java, "Session token renewal request is rejected by AAA" message
Hi I tested the TRCC tutorial code for EMA Java and the following messages returned.
(User name and Password are removed from the messages for the security reason)
----- Status message ----
StatusMsg
streamId="5"
domain="System Domain"
privateStream
state="Open / Ok / None / ''"
name="TUNNEL1"
serviceId="10"
serviceName="DDS_TRCE"
StatusMsgEnd
StatusMsg
streamId="5"
privateStream
state="Closed / Suspect / Not entitled / 'Session token renewal request is rejected by AAA.'"
name="XXX"
serviceId="10"
Attrib dataType="ElementList"
ElementList
ElementEntry name="Password" dataType="Ascii" value="XXX"
ElementListEnd
AttribEnd
StatusMsgEnd
StatusMsg
streamId="5"
privateStream
state="Closed, Recoverable / Suspect / None / 'channel down.'"
name="TUNNEL1"
serviceId="10"
StatusMsgEnd
I tested it ETE (Elektron Test Environment) as I was only allowed to have ID for TRCC test.
How to fix this issue? Can I fix it by EMA code?
Or do I need to call TR help desk to do something on ETE side?
Best regards
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apircc-api
@hiroyuki.tanaka I tried your username/password combination, and there seems to be an issue with your credentials. Please contact the TRCC product team to get a valid one.
Thank Gurpreet,
Asking the product team the valid credentials. Will test it again once I get it.
Thank you.
Thank you. The problem has gone with the new credential.
