ThomsonReuters.Desktop.SDK.DataAccess.dll Location
I just recently started with the EIKON .NET api and I was able to get the example code (DataApiUsageExampleRealtimeData) working just fine. Since then I've tried to create my own project from scratch and have encountered some issues. Following the instructions to install the nuget package 'Eikon 4 Desktop Data APIs' the closest match I could find was the EikonDataAPI which was missing the ThomsonReuters.Desktop.SDK.DataAccess.dll and many other files. Following the Tutorials section I tried loading "Install-Package ThomsonReuters.Desktop.SDK.DataAccess.Signed" via the nuget command prompt and it was unable to find the package.
So I'm kind of treading water here wondering where I go to get copy of the API.
eikoneikon-data-apieikon-com-api
@tobermark
Thanks for reporting this. After the packages have been reinstated the default download version became the unreleased v1.9.1. We're removing this version of the package from NuGet. In the meantime you can install the latest production release v1.8.4 by specifically targeting this version:
PM> Install-Package ThomsonReuters.Desktop.SDK.DataAccess.Signed -Version 1.8.4
Eikon .NET SDK packages have been inadvertently taken down from NuGet. We're working on restoring these packages. We'll update this thread as soon as the packages are restored.
Eikon .NET SDK packages have been reinstated on NuGet and are available for download.
Apparently there's a dependency that's still having an issue?
Attempting to resolve dependency 'Newtonsoft.Json (≥ 6.0.8)'.
Attempting to resolve dependency 'ThomsonReuters.Udap.Ipc.Signed (≥ 2.10.10)'. Install-Package : Unable to resolve dependency 'ThomsonReuters.Udap.Ipc.Signed (≥ 2.10.10)'. At line:1 char:2 + Install-Package ThomsonReuters.Desktop.SDK.DataAccess.Signed + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: (:) [Install-Package], InvalidOperationException + FullyQualifiedErrorId : NuGetCmdletUnhandledException,NuGet.PowerShell.Commands.InstallPackageCommand PM>
The unreleased versions of the packages have been unlisted from NuGet. The current version available on NuGet is now the latest production release v1.8.4.
