How can I retrieve type in the API call that retrieves profile ? Where is it in the JSON text ?
Type means: PEP, OB ...etc.
I want the exact equivalent of the information from the UI when viewing a profile. (see below screen shot)
Yes, the category note(retrieve type) PEP and subcategory will be displayed in JSON response returned by the API "SEQ-5c: Get a World-Check profile" if the world check profile is a PEP.
In order to determine, if the profile is a PEP/OB, you can look at the attribute "category", "subCategory" and "sources" in the response body of the API.
Please find an example of JSON response in the attached. I have highlighted the attributes and their values which would provide the PEP(retrieve type) information.
I request you check the schema reference document to the 2294-cusersu6068964documentspep-json-response-body.pdf entire list of attributes that are featured on the JSON response body.
