RFA and our TREP capabilities
Hi community:
I'm very new to RFA development and would like to reach out with just a newbie question about connection capabilities (if you don't mind).
When I connect to our site's TREP, I receive the following warning in the RFA connection log:
(ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL" does not support views. View requests will be converted to full item requests for this connection.
Q1: Does the above warning mean that I cannot reduce the amount of fields returned by an interest request to TREP?
I also receive another warning:
(ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL" does not support Pause/Resume. Pause and Resume requests for this connection will be ignored.
Q2: Does the above mean that I have no way to suspend any interest request marked with ReqMsg.InteractionTypeFlag.InterestAfterRefresh ?
Any assistance will be very much appreciated.
Regards,
Craig.
treprfarfa-api
18k 21 12 20
Hi @frenchc
According to the log message, you are correct that the component you connected to does not support view feature and pause/resume feature.
So you will not be able to set interested fields to your item subscription, pause nor resume your streaming request.
The availability of features depends on your TREP version and license.
Please contact your local TRM (technical relationship manager) to find out more detail.
Please be informed that the RFA API is a feature-completed API. The current strategic API is Elekton Message API (EMA Java API) which is a part of the strategic Elektron SDK family. You can find more detail regarding the EMA Java from the following resources
Thank you so much for your quick and clear response, Chavalit. Our organisation will be updating their TREP infrastructure in the near future to take advantage of the SDK you mentioned.
