get_data issue with adjusted/unadjusted
Please check the outputs of the following two requests:
adjusted = eikon.get_data("CRH.L", "TR.ClosePrice.Value", {"Adjusted":"1", "SDate": "20090101", "EDate": "20180522", "Frq":"D", "curn":"GBp"})
unadjusted =eikon.get_data("CRH.L", "TR.ClosePrice.Value", {"Adjusted":"0", "SDate": "20090101", "EDate": "20180522", "Frq":"D", "curn":"GBp"})
There is an error in the conversion in 2011 (November 8 and before), it should be in the range of 1000 pence. Excel gives the same output. Any ideas what's happening here? Thanks for your help!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythondataunadjusted
@Joris.Hoendervangers
This forum is not the best place to dispute whether price adjustment was performed correctly for a given stock on a given day or to raise any other data issues for that matter.
I suggest you direct your data query via normal support channels, i.e. raise a case with TR Helpdesk, especially since the data you're questioning is easily retrieved using Excel.
You are right. Submitted to the Helpdesk, case 06616069
