Linking errors after updating to 1.2.0
After inplace upgrading from 1.1.1 to 1.2.0 I've got a bunch of linking errors like these:
1> libema.lib(ItemCallbackClient.obj) : error LNK2001: unresolved external symbol rsslDecodeArray
What am I doing wrong? VS2017 if this matters (I don't think so).
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apic++
I figured out how to fix it: it looks like previously ETA libs were linked in the libema.lib, with 1.2.0 release they are separated out and placed under Elektron-SDK1.2.0.win.rrg\Cpp-C\Eta\Libs.
After specifying them in AdditionalDependencies explicitly (and copying over):
<AdditionalDependencies>libxml2.lib; librsslVA.lib; librssl.lib; libema.lib; ws2_32.lib; wininet.lib;%(AdditionalDependencies)</AdditionalDependencies>
Compilation went successful.
This is something needs to be brought to https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time-opnsrc/rt-sdk-cc/tutorials#ema-c-compiler-settings as it states that only libema.lib is needed (but I asked it in a separate thread).
9.7k 49 38 60
Hi @maratu,
The ESDK 1.2 release has made some changes to some of the libraries that may affect the linking of existing applications. Refer to the Migration Guide within the ESDK C/C++ documentation.
Also, try to use the new CMake build system to generate the project files for the examples as outlined within the Migration Guide. This will allow you to compare the linking/compiler includes and libs as a comparison to your project build files.
