How to read TTL/n-triple dumps?
I got organisations ttl file from https://permid.org/download. While trying to parse it with RDFLib, I get parsing errors. I tried it with n-triple file as well.
How do I read this file? I want to convert this to csv and I'm open to any programming language to do so.
intelligent-tagging-apipermid-apiopen-permid-apirdf
I found one solution to convert the ttl to csv in stack overflow. It uses arq command in Apache Jena.
To convert to CSV, I have to create a SPARQL query.
For example, the query for converting OpenPermID-bulk-assetClass-20180506_071050.ttl to CSV looks like:
The above query is saved in assetQuery.rq.
Then, run the arq tool.
arq --data Open
PermID-bulk-assetClass-20180506_071050.ttl --query assetQuery.rq --results csv > asset.csv
The content in asset.csv file is:
