is there an API to provide the person Search using the PEP ID or Profile ID , whatever ID WorldCheck / Thomson reuters maintain for PEPs
Hello @Vanessa Lucisano,
Yes, all the fields and its possible values that will be returned by calling the API "SEQ-5c: Get a World-Check profile" is documented in the WC1 API schema reference document. The "WC1 API schema reference document" is part of the API documentation which can be downloaded from the developer community portal. You can refer to it to understand the fields that are returned as a response.
Please find the complete path to navigate to the mentioned document:
Thomson-Reuters-World-Check-One-API-documentation.v1.3.zip --->documentation --> schema-reference -->WC1 API schema reference document.html
Once you are in the doc, click on the "Get a profile by its ID" in the table of contents (which would be on the left side of the screen) to get all the fields and its related schema.
Hello @jyoti.surooprevo ,
You can use the API call "SEQ-5c: Get a World-Check profile" to view the complete world check profile of entities.
Hi @Irfan.Khan,
do we have a list of the fields that will be returning via WCONE API, using Seq-5c?
