Batch profiles Request
Can we make a batch request for profiles as opposed to making a separate request for each of them? Which API does it ?
world-checkworld-check-onebatch
4.5k 4 7 8
Hi @jyoti.surooprevo,
As of now batch request of profile data is not possible through API. Please refer to the below link for more information on it :
https://community.developers.refinitiv.com/questions/21514/multiple-api-calls-for-each-connections-relationsh.html?childToView=26723#answer-26723
@Prabhjyot.Mandla , we are currently using a Screening System that uses the World Check PEP list for screening the Banks customers, the results from the screening we get the watch list IDs already. We would like to use the watch list ID from our system to get the complete profile of the Watchperson . So which API would suit for that is my question ? While we have the profile of the watchperson , it is not readable ; and also we want to operationally validate against the latest profile of the watchperson profile because the PEP list we are using is not updated on the daily basis but weekly.
4.5k 4 7 8
@jyoti.surooprevo,
Can you please let me know if you want to use your own customized PEP list and watchlist to screen the clients? If yes, you can call the API - "SEQ-5c: Get a World-Check profile"
using the watchlist ID to view the uploaded watchlist details, which will return the result in JSON format.
Can you also please elaborate, what exactly do you mean by "Watchperson"?
