Bulk Response request from WC
Hi ,
Is there an API that can respond to Bulk Watchlist IDs (input) and respond with all the Profiles against Watchlist IDS provided
world-checkworld-check-onebulk-download
4.2k 7 5 6
Hi @jyoti.surooprevo ,
We do not have an API that can respond to bulk Watchlist IDs and respond with all the Profiles against Watchlist IDs provided.
You have to make a separate API call for each Watchlist ID to receive its respective watchlist profile as a response. You can use the API call "SEQ-5c: Get a World-Check profile" to achieve this. This API call can pull both the world check profile (using the world check ID) and the watchlist profile (using the watchlist ID).
Please let me know if this was helpful, by accepting the answer.
