@sreedhanya.kavunkara, please tell us exactly:
You want to pull end of day data (TRADE_DATE and LAST_PRICE) for around 25000 RICs everyday.
How to identify the API call that delivers the fields you want
You can use the data dictionary to identify which calls deliver the fields you want. In sheet Field Descriptions, search in column Field Name for Last, and you will see that the Elektron Timeseries call delivers it. It also delivers a Trade Date.
A call can be done On Demand or be scheduled. These 2 approaches are described in the Tutorials Introduction.
The Elektron TimeSeries call
The Elektron Timeseries call delivers End of Day data. REST API Tutorial 7 describes this call and its parameters, done using an On Demand request, with the 2 fields you are interested in (and a few more). You can refer to the API Reference Tree for additional information on the parameters (you must first select the appropriate call in the first parameter's dropdown, i.e. ElektronTimeSeriesExtractionRequest).
Implement the call in your Python code
We do not have a Python sample for this call, but it would be easy for you to make one, using the TRTH_OnDemand_IntradayBars sample (available in the downloads) as a starting point. In step 2 you need to implement a way to populate the InstrumentIdentifiers array. You must change the requestBody to do an Elektron Timeseries call, with your parameters. As you have 25k instruments, delete step 4. Step 5 will save the data to file. Step 6 can be deleted as well, it is purely cosmetic.
@sreedhanya.kavunkara, a new version of the on demand Python sample is available under the downloads tab. It has been enhanced to manage an eventual initial HTTP 200 response (which is rare but could happen, as you saw when changing the type of request). Hope this helps.
