Incorrect format for links in PermId RSS feed
When a RSS document is requested using a URL such as:
https://permid.org/atom/instrument?access-token=XXX
the links in the returned Atom document look as follows:
<link rel="next" href="https://api.thomsonreuters.com/permid/atom/instrument&offset=50&length=50" />
 <link rel="self" href="https://api.thomsonreuters.com/permid/atom/instrument&offset=0&length=50" />
<link rel="first" href="https://api.thomsonreuters.com/permid/atom/instrument&offset=0&length=40" />
 <link rel="last" href="https://api.thomsonreuters.com/permid/atom/instrument&offset=100&length=40" />
but instead of containing:
&offset=50
it should be:
?offset=50
The links as they currently stand are not valid and can't be retrieved
Regards,
David
intelligent-tagging-apipermid-apiopen-permid-api
@david.snowsill
I found that the problem has been resolved. The returned response is:
 <link rel="next" href="https://api.thomsonreuters.com/permid/atom/instrument?offset=50&length=50" />
    <link rel="self" href="https://api.thomsonreuters.com/permid/atom/instrument?offset=0&length=50" />
    <link rel="first" href="https://api.thomsonreuters.com/permid/atom/instrument?offset=0&length=50" />
    <link rel="last" href="https://api.thomsonreuters.com/permid/atom/instrument?offset=100&length=30" />
Thanks for your help with this. Are there any updates on the other issues I have opened?
Regards,
David
@david.snowsill
Yes, you are correct. It should be ?offset=50 instead of &offset=50.
I will contact the support team to verify it.
@david.snowsill
The estimated plan for the fix of this issue is on next month (10 June).
Has this fix been rolled out yet?
Regards,
David
The links are still incorrect. I have contacted the support team to verify it.
Thanks for the update
David
