cannot control the output layout of get_data
    rics = ['0001.HK', '0002.HK']
    params = {'Frq': 'C', 'Period': 'FY2', 'Curn': 'USD', 'SDate': '2018-04-17','EDate':'2018-04-18','CH':'IN','RH':'calcdate'}
    rsp, err = ek.get_data(instruments = rics, fields = 'TR.EPSMean', parameters = params)
I hope the row header is date and the column header is instruments.
but the result is:
rsp
Out[69]:
  Instrument  Earnings Per Share - Mean
0    0001.HK                   1.375680
1    0001.HK                   1.378931
2    0002.HK                   0.628250
3    0002.HK                   0.628250
It does not show date information.
4.6k 26 7 22
@charles.wang change the fields list to
fields = ['TR.EPSMean.date', 'TR.EPSMean']
Thanks. It works, if using
fields = ['TR.EPSMean.calcdate', 'TR.EPSMean']
TR.EpsMean.date seems giving the date when the estimate is released.
but it still cannot control the output layout, if I prefer row header = date and column header = instruments. I hope the result would be like:
rsp.pivot(index = 'Calc Date', columns = 'Instrument', values = 'Earnings Per Share - Mean')
Out[78]:
Instrument   0001.HK  0002.HK
Calc Date
2018-04-17  1.375680  0.62825
2018-04-18  1.378931  0.62825
but I am OK with this.
Thanks.
