Reconnection for "Access Denied-already using position"
Hi Team,
1. Is there an option to retry connection for the following error?
2. Any parameter in EmaConfig.xml which I can use for "Access Denied-already using position" or to extend the time limit for exception "timed out after waiting 45000 milliseconds" ?
3. I would like to attempt the connection for max of 3 mins instead of the default 45 secs.
Thanks,
Sagar
State: Closed/Suspect/Maximum logins reached - text: "Access Denied-already using position XX.XX.XX.XX"
loggerMsgEnd
Apr 02, 2018 5:05:50 PM com.thomsonreuters.ema.access.OmmBaseImpl handleLoginReqTimeout
SEVERE: loggerMsg
ClientName: Consumer_Test_1
Severity: Error
Text: login failed (timed out after waiting 45000 milliseconds) for XXX:XXX)
loggerMsgEnd
2018-04-02 17:05:50.597 ERROR run(): Exception thrown: login failed (timed out after waiting 45000 milliseconds) for XXX:XXX)
elektronrefinitiv-realtimeelektron-sdk
9.5k 10 5 7
Hello @sagar.s
Based on our test, increase LoginRequestTimeOut does not help to solve this problem. Because the login stream has closed already as shown in your message:
In this case, EMA does not retry to login to ADS anymore.
According to my test, I set LoginRequestTimeOut to 180000 and run 3 applications logged in using the same user while DACS allows 2 concurrent logins for this user. Hence, the 3rd application got the error message above. After 1 minute, the two application exited. Hence, the number of login was 0 and the 3rd application should be able to login to ADS. However, EMA did not retry to login to ADS because the login stream closed already. Finally, the application exited according to login request timeout.
To solve this problem, please contact your DACS administrator or Thomson Reuters Account team if DACS is hosted by Thomson Reuters to increase “Allowed Simultaneous Login” parameter in DACS to fit your usage.
Normally, EMA will retry to login to ADS when the login's state is still open e.g. when ADS goes down, the application will get:
Apr 04, 2018 1:13:02 PM com.thomsonreuters.ema.access.LoginCallback
Client rdmLoginMsgCallback
WARNING: loggerMsg
	ClientName: LoginCallbackClient
	Severity: Warning
	Text:  RDMLogin stream state was changed to suspect with status message
	username <not set>
	usernameType <not set>
	State: Open/Suspect/None - text: ""
loggerMsgEnd
Notice that the login stream's state is still open but it is suspect. When ADS goes up again, EMA can login to ADS successfully.
9.5k 10 5 7
Hello @sagar.s
"Access Denied- already using position" occurs when several applications try to login using the same user to ADS with DACS enabled. The number of concurrent user login exceeds “Allowed Simultaneous Login” parameter in DACS. To solve this error, please contact your DACS administrator or Thomson Reuters Account team if DACS is hosted by Thomson Reuters to increase “Allowed Simultaneous Login” parameter in DACS to serve your usage.
The login timeout can be set in LoginRequestTimeOut parameter of Consumer node as explained in Table 3: Consumer Group Parameters (Continued) in <Elektron-SDK Java>\Ema\Docs\EMAJ_ConfigGuide.pdf shown below:
Hence, to set max 3 minutes login timeout, add LoginRequestTimeOut with value 180000 to the Consumer node your application use(default is Consumer_1) in EmaConfig.xml as example below:
<Consumer>
        <Name value="Consumer_1"/>
        <LoginRequestTimeOut  value="180000"/>
</Consumer>
I tried to set this parameter to be 180000 and EMA Java waited for login response 3 minutes as shown below:
Apr 04, 2018 10:34:48 AM com.thomsonreuters.ema.access.OmmBaseImpl handleLoginReqTimeout
SEVERE: loggerMsg
    ClientName: Consumer_1_1
    Severity: Error
    Text:    login failed (timed out after waiting 180000 milliseconds) for localhost:14002)
loggerMsgEnd
