The max number of the "limit" parameter of /entity/search is 100 as described in the Data Fusion API Document, so I requested the data using /entity/search setting 100 for the parameter and received the responce.
limitThe maximum number of records to return per page. Default of 50, max of 100.The value of "totalCount' field in the response is 279,893, but when I try to show list all the label of the response, I can show only 100 values in the "label" field on the first page and can't show the other 279,793 as you can see in the attached.
Could you please let me know how to access the remaining values of the "label" field on the 2+ pages?
Your prompt clarification would be very helpful!
