Retrieve current historic volatility surface
I am wondering what the most elegant way to retrieve a full surface through the Python API is. For example LCOSURF3 contains a lot of RICs like LCO100N1MO=R for which historic as well as live values can be retrieved. Is there another way except pulling the data RIC by RIC?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-seriesvolatility
Hello @peter.stein,
Thank you for your participation in the forum.
Is the reply below satisfactory in resolving your query?
If yes please click the 'Accept' text next to the reply. This will guide all community members who have a similar question. Otherwise please post again offering further insight into your question.
Thanks,
-AHS
4.6k 26 7 22
I can not see any elegant ways to achieve this, moreover, the api does not consider a chain of instruments without 0# as a series, so you will have to extract RICs first with something like this:
import pandas as pd
import eikon as tr
tr.set_app_id('your_app_id')
fields = ['LONGLINK' + str(i) for i in range(1, 14)] + ['LONGNEXTLR']
def expand_chain(ric, fields, data):
    df, e = tr.get_data([ric], fields)
    data = data + list(df.iloc[0])[1:-1]
    nextlr = df['LONGNEXTLR'][0]
    if (pd.isnull(nextlr)):
        return data
    else:
        return expand_chain(nextlr, fields, data)
rics = expand_chain('LCOSURF3', fields, [])[1:-1]
after this you can get the time series for each RIC.
