RFA Java API Data Problem
I am using the RFA Java API. I'm trying to get the following RIC information every 3 minutes. Sometimes this information is full and sometimes only a few of them come. From the logs I see an expression like "Message type: MsgType.REFRESH_RESP" . After every RIC information. Below I send RIC and used field information.
Best Regards...
ItemManager: Subscribing to EUR=
ItemManager: Subscribing to GBP=
ItemManager: Subscribing to TRY=
ItemManager: Subscribing to CHF=
ItemManager: Subscribing to JPY=
ItemManager: Subscribing to AUD=
ItemManager: Subscribing to CAD=
ItemManager: Subscribing to NOK=
ItemManager: Subscribing to SEK=
ItemManager: Subscribing to DKK=
ItemManager: Subscribing to RUB=
ItemManager: Subscribing to THB=
ItemManager: Subscribing to CNY=
ItemManager: Subscribing to XAU=
ItemManager: Subscribing to AED=
ItemManager: Subscribing to INR=
ItemManager: Subscribing to CNH=
ItemManager: Subscribing to RON=
ItemManager: Subscribing to XPT=
ItemManager: Subscribing to EURGBP=
ItemManager: Subscribing to EURCHF=
ItemManager: Subscribing to EURRUB=
ItemManager: Subscribing to EURSEK=
ItemManager: Subscribing to EURNOK=
ItemManager: Subscribing to EURJPY=
ItemManager: Subscribing to EURAED=
ItemManager: Subscribing to EURCAD=
ItemManager: Subscribing to GBPCHF=
ItemManager: Subscribing to CHFJPY=
ItemManager: Subscribing to EURDKK=
ItemManager: Subscribing to EURRON=
  FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         4.6645    FieldEntry, FID   25, name ASK,        type REAL:         4.669700000000001    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
currentTimeMillis : 1521619490529
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         1.3394000000000001    FieldEntry, FID   25, name ASK,        type REAL:         1.3399    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> GBPbidAmount -> 1.3394000000000001askAmount -> 1.3399currencyMarket -> CHFdominantCurrency -> GBPfxName -> GBPCHFitemName -> GBPCHF=
currentTimeMillis : 1521619490530
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         111.29    FieldEntry, FID   25, name ASK,        type REAL:         111.35000000000001    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> CHFbidAmount -> 111.29askAmount -> 111.35000000000001currencyMarket -> JPYdominantCurrency -> CHFfxName -> CHFJPYitemName -> CHFJPY=
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         1.6004    FieldEntry, FID   25, name ASK,        type REAL:         1.6005    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> EURbidAmount -> 1.6004askAmount -> 1.6005currencyMarket -> CADdominantCurrency -> EURfxName -> EURCADitemName -> EURCAD=
currentTimeMillis : 1521619490531
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         7.4485    FieldEntry, FID   25, name ASK,        type REAL:         7.449000000000001    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> EURbidAmount -> 7.4485askAmount -> 7.449000000000001currencyMarket -> DKKdominantCurrency -> EURfxName -> EURDKKitemName -> EURDKK=
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         0.8751    FieldEntry, FID   25, name ASK,        type REAL:         0.8756    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> EURbidAmount -> 0.8751askAmount -> 0.8756currencyMarket -> GBPdominantCurrency -> EURfxName -> EURGBPitemName -> EURGBP=
currentTimeMillis : 1521619490532
    FieldEntry, FID   15, name CURRENCY,   type ENUM:         <blank>    FieldEntry, FID   22, name BID,        type REAL:         6.3304    FieldEntry, FID   25, name ASK,        type REAL:         6.3315    FieldEntry, FID 1001, name GV2_TEXT,   type RMTES_STRING: Reuters: currencyName -> EURbidAmount -> 4.6645askAmount -> 4.669700000000001currencyMarket -> RONdominantCurrency -> EURfxName -> EURRONitemName -> EURRON=
Reuters: currencyName -> USDbidAmount -> 6.3304askAmount -> 6.3315currencyMarket -> CNYdominantCurrency -> CNYfxName -> USDCNYitemName -> CNY=
treprfarfa-apirefresh-message
Hello @hasan.cakar
Please see my response in the email
RE: Case 06424387 TR Yardim Masasi [ ref:_00D30602X._5001W1FHkO2:ref ]
which just have sent to you.
9.5k 10 5 7
According to the given info in the case, the client run application only 1 second which was too short to get data of all RICs. After the client increased the run time/waiting time, the problem has been solved; he could get data of all RICs.
MsgType.REFRESH_RESP which the client have seen is the first data message the application receives from the server after an application subscribes a RIC/item. It contains all currently available information about the item e.g. the item’s state and the data in the payload. The payload contains the field list(list of FieldEntry) includes all the fields that may be present in subsequent update messages. For more details of MsgType.REFRESH_RESP, please refer to MarketPrice Refresh Message section in [RFA Java package]\Docs\RFAJ_RDMUsageGuide.pdf.
The client was satisfied with our solution above so the case has been closed.
