Hi team,
I tried the sample code provided previously on a C# console project, which worked.
I however found the same set of code not working in a web application project (MVC.Net) when I paste the code in C# controller. I am getting the following error. Pasted the full code below and masked the api key and api secret.
static void Main(string[] args) { DateTime dateValue = DateTime.UtcNow; // get the datetime NOW GMT string date = dateValue.ToString("R"); // WC1 header requires GMT datetime stamp Console.WriteLine(date); //set host and credentials to the WC1 API Pilot server WC1SampleClientAPI account string gatewayurl = "/v1/"; string gatewayhost = "rms-world-check-one-api-pilot.thomsonreuters.com"; // Here is where you enter your api keys string apikey = ""; string apisecret = ""; string requestendpoint = "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/groups"; // Assemble the GET request - NOTE every character including spaces have to be EXACT // for the API server to decode the authorization signature string dataToSign = "(request-target): get " + gatewayurl + "groups\n" + "host: " + gatewayhost + "\n" + // no https only the host name "date: " + date; // GMT date as a string // The Request and API secret are now combined and encrypted string hmac = generateAuthHeader(dataToSign, apisecret); // Assemble the authorization string - This needs to match the dataToSign elements // i.e. requires ONLY host date (no content body for a GET request) //- NOTE every character including spaces have to be EXACT else decryption will fail with 401 Unauthorized string authorisation = "Signature keyId=\"" + apikey + "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"" + hmac + "\""; // Send the Request to the API server HttpWebRequest WebReq = (HttpWebRequest)WebRequest.Create(requestendpoint); // Set the Headers WebReq.Method = "GET"; WebReq.Headers.Add("Authorization", authorisation); WebReq.Headers.Add("Cache-Control", "no-cache"); WebReq.Date = dateValue; // use datetime value GMT time // Get the Response - Status OK HttpWebResponse WebResp = (HttpWebResponse)WebReq.GetResponse(); // Status information about the request Console.WriteLine(WebResp.StatusCode); Console.WriteLine(WebResp.ResponseUri); // Get the Response data Stream Answer = WebResp.GetResponseStream(); StreamReader _Answer = new StreamReader(Answer); string jsontxt = _Answer.ReadToEnd(); // convert json text to a pretty printout //var obj = Newtonsoft.Json.JsonConvert.DeserializeObject(jsontxt); //var f = Newtonsoft.Json.JsonConvert.SerializeObject(obj, Newtonsoft.Json.Formatting.Indented); //Console.WriteLine(f); Console.WriteLine("Press any key"); Console.ReadKey(); // pause for any key } // Combine the data signature and the API secret key to get the HMAC // This is the Microsoft HMACSHA256 code copied from the documentation public static string generateAuthHeader(string dataToSign, string apisecret) { byte[] secretKey = Encoding.UTF8.GetBytes(apisecret); HMACSHA256 hmac = new HMACSHA256(secretKey); hmac.Initialize(); byte[] bytes = Encoding.UTF8.GetBytes(dataToSign); byte[] rawHmac = hmac.ComputeHash(bytes); return (Convert.ToBase64String(rawHmac)); }
