document on RFA messages & meaning
would you share document on each RFA messages & relevant meaning ?
treprfarfa-api
9.5k 10 5 7
Hello @tim.hung
There is no official documentation that lists all possible RFA Java Error OMM messages(MsgType.STATUS_RESP) and RFA Exceptions. However, the common Errors/Exceptions based on my team experiences are listed in the attachment.
possible-rfaj-statusmessages-exception.zip
The attachment also includes the possible root causes and their solutions.
Note: Some RFA OMM messages are received from ADS(A<number>) e.g.A20 or ADH(F<number>) e.g.F10. For the other errors sent from ADS/ADH, please refer to ADS/ADH documents.
The documents are in the RFA packages and available online at:
Please refer to RFA C++ RDM Usage Guide, RFA .NET RDM Usage Guide or Reuters Domain Models (RDM) documents for the usages and meanings of messages in each domain.
You can also refer to Developers Guide regarding how to use RFA messages.
i see those c++,java, .net developer guides. but cant find those RDM usage guide, would you guide where to find.
I have the rfa java api v7.5 developers guide, which chapter will list those rfa messages & what they mean ?
RDM Usage Guides are available online, as mentioned in the previous answer.
For RFA Java, the document name is Reuters Domain Models (RDM).
In RFA Java Developers Guide, you should read Chapter 2 RFA Concepts and Chapter 3 OMM Package.
noted. Which document will list common RFA error messages and meaning ? such as concurrent logon denied, service denied or permission denied ?
