Ric Not Found vs Permission Denied in API
In native clients there are different messages for:
- wrong RIC name input
- lack of access to RIC data
- source Stale
How can I distinguish those using RFAJ subscription?
treprfarfa-api
1.9k 6 9 16
Hello @pawel.c,
I assumed that you are using OMM interface of RFA Java application connecting to the infrastructure (i.e. TREP: ADH, ADS)
Here there are sample messages under different situations:
1. wrong RIC name input
This can be interpreted as non-existing RIC name. When this problem occurs, "The record could not be found" will appear.
ItemManager.processEvent: Received Item Event...
2018-03-05 19:11:27.313+0700
MESSAGE
	Msg Type: MsgType.STATUS_RESP
	Msg Model Type: MARKET_PRICE
	Indication Flags:
	Hint Flags: HAS_ATTRIB_INFO | HAS_STATE
	State: CLOSED, SUSPECT, NOT_FOUND,  "The record could not be found"
	AttribInfo
		ServiceName: API_ELEKTRON_EPD_RSSL
		ServiceId: 2115
		NameType: 1 (RIC)
	Payload: None
2. lack of access to RIC data. The related scenarios can be as follows:
(a) unauthorized access
2018-03-05 19:20:01.061+0700
MESSAGE
	Indication Flags:
	State: CLOSED, SUSPECT, NOT_ENTITLED,  "Access Denied: User req to IDN for Exch - HKG"
	AttribInfo
		ServiceName: RED3_ELEKTRON_EDGE_TOKYO
		ServiceId: 1221
		NameType: 1 (RIC)
	Payload: None
Remark: We tried to test a Euro user subscribes to Hong Kong instrument.
(b) Server capacity limited
2018-03-05 19:31:05.607+0700
MESSAGE
	Indication Flags:
	State: CLOSED, SUSPECT, TOO_MANY_ITEMS,  "A20: Item limit per service exceeded."
	AttribInfo
		ServiceId: 4012
		NameType: 1 (RIC)
	Payload: None
3. source Stale
Stale is represented as 'SUSPECT' in OMM.
2018-03-05 19:35:06.777+0700
MESSAGE
	Indication Flags:
	State: OPEN, SUSPECT, NONE,  "A23: Service has gone down. Will recall when service becomes available."
	AttribInfo
		ServiceName: API_ADH_NI_PUB
		ServiceId: 8500
		NameType: 1 (RIC)
	Payload: None
These are examples error messages that can be found under the situations given. An attribute of the messages that conveys details is 'State'. Referring to the examples given above, State contains four sub-attributes as follows:
  • Stream State - returns the Stream value such as OPEN, NONSTREAMING, REDIRECT, CLOSED, CLOSED_RECOVER.
  • Data State - returns the Stream value such as OPEN, NO_CHANGE, SUSPECT.
  • Code - returns the Stream value such as ALREADY_OPEN, ERROR, DACS_DOWN, NOT_FOUND, TOO_MANY_ITEMS, etc..
  • Text - returns information as String.
Code and Text sometimes correspond to each other. For example,
  • Code: 'NOT_FOUND' and Text: 'The record could not be found'
  • Code: 'NOT_ENTITLED' and Text: Access Denied: 'User req to IDN for Exch - <XXX>'
  • Code: 'TOO_MANY_ITEMS' and Text: 'A20: Item limit per service exceeded.'
You can find more details of RFA Java's Stream States, Data States, and Codes from RFAJ_DeveloperGuide.pdf which was normally included in <RFA Java Package>/Docs folder.
Furthermore, if you are connecting to TREP infrastructure, you can find information regarding error messages from the installation guide which was also delivered with the package as well
Anyway, please be aware of that these messages as some of them don't appear in the exact phrases/sentences because they depend on a scenario and the connecting server that may customize them too. For instance, if you don't have the authorization to access an instrument from STOCK EXCHANGE OF THAILAND, the text will be 'Access Denied: User req to IDN for Exch - SET' instead of 'Access Denied: User req to IDN for Exch - HKG'.
Hope this helps!
Hi @pawel.c
Just to add a small note to Nipat excellent and comprehensive answer.
As Nipat mentioned,the text message can vary somewhat. The key thing here is that you should not rely on parsing the text to control programmatic behaviour. The text should only be used for displaying message / diagnostic logging type stuff. You should use the numeric OMMState.Code attribute instead.
