407 Proxy Authentication Request
Hi team,
Getting this request in an implementation in C#, even sample code is used.
The weird observation is that sometimes the API is called successfully and sometimes below error is shown. I would expect the behavior is consistence.
Thanks for the help.
world-checkworld-check-oneproxy
Hi @cliff.ching,
The error you are getting is not from the API.It is something to do with your system proxy setting.
Hope this helps.
Rakesh
