Is there a request to delete a case via WC1 API ?
Hi @nabil.hassoumi ,
No,we don't have a request to delete a case through World Check API.
Hope this helps.
Rakesh
The delete API feature is now live as API service with the release of 1.5 documentation.
'Case delete' option needs to be enabled by the Customer Entitlement Team for the specific client, so that they may be able to delete the cases. It is not enabled by default for the account.
After the account has been enabled with the 'Case delete' access, please follow the below instructions to delete a case using World-Check One API.
Pre-checks :
Permission to 'Delete a case' should be added for the specific Group, User and Role.
Permissioning:
Go to Admin section from UI > Roles > Select the specific group to see the permissions
> If 'Delete a case' is not under the permissions - click on Edit and add the 'Delete a case' option > Save
Once the above permissions have been granted, you can then call the below API calls to delete a case -
Step 1 :SEQ-case-archive: Archive a case - In order to delete a case, the case should be first archived.
Step 2 :SEQ-case-delete: Delete a case
Response code for a successful deletion of case is 204
Note :
- A case can only be delete once it is archived.
