Screen an organisation and set up the group
can you sent us more detail on how to implement for the following on world check one?
1)API call for screening on company name
2)New group create process if we need separate screen rules for the new API call
world-checkworld-check-one
1)API call for screening on company name: There is a spate request called as SEQ-2d: Save a case: Organisation (see below screen shot for your reference) which you can use to send the organization/company names for screening. Rest of the process remains the same.
2)New group create process if we need separate screen rules for the new API call: Please see attached document on how you can set up groups and have different screening settings for each group. The same is also available in UI portal à Help section.
