IndexOutOfBoundException during RFA Login
Hi, I need your help for below error.
In our app we are using Java RFA to receive market data. When I send login request RFA shows "Failed connection:IndexOutOfBoundsException:
Please note that oOur ADS server does not receive any login message.
I am also seeing some strange un-readable characters in response message. Detail response message is shown below. Can anyone point out whats going wrong here? and how to interpret this error?
I am initializing my encoder with below mentioned size.
OMMEncoder encoder = ommPool.acquireEncoder();<br>encoder.initialize(OMMTypes.MSG, 50000);
Response message from RFA (using GenericOMMParser provided in RFA examples)
MESSAGE
	Msg Type: MsgType.STATUS_RESP
	Msg Model Type: LOGIN
	Indication Flags:
	Hint Flags: HAS_ATTRIB_INFO | HAS_STATE
	State: OPEN, SUSPECT, NONE,  "Ø(
yConnection to tkrmdsdev01.nomura.com:14002 failed in connection Tiger::RFAFeed: java.lang.IndexOutOfBoundsException: nullR&jitkarrF
ApplicationId?215Position?10.199.92.165/MUMWD041460Role"
	AttribInfo
		NameType: 1 (USER_NAME)
		Attrib
			ELEMENT_LIST
				ELEMENT_ENTRY ApplicationId: Ø(
				ELEMENT_ENTRY Position: Ø(
				ELEMENT_ENTRY Role: 0
	Payload: None
treprfarfa-api
Hi @Umer Nalla
1. I am using RFA 6 and Java sdk 1.6
2. Standard example works perfectly fine.
In fact when I run my app from within Intelij, it works perfectly fine. However when I bundle app (with gradle) into a Java webstart WAR file then it fails and RFA gives above junk output.
Application logs correctly shows the configuration parameters like, server list, connection type RSSL etc.
Since issue does not occure while running from IDE (Intelij) I am not able to proceed ahead with debug or investigation.
@ramesh.jitkar
May I get the LOGIN result when you run the application in Intelij?
I suspected that this problem might relate to character encoding.
Also, according to stackoverflow.com, there are some suggestions regarding gradle build encoding settings:
compileJava.options.encoding = 'UTF-8'
tasks.withType(JavaCompile) {
apply plugin: 'java'
repositories {
    mavenCentral()
test {
    systemProperty "file.encoding", "utf-8"
org.gradle.jvmargs='-Dfile.encoding=UTF-8'
Hi @ramesh.jitkar
A few questions:
  1. What version of RFA API are you using and which Java SDK version?
  2. Does this problem occur when using one of the standard examples that comes with the RFA Java SDK e.g. QuickStartConsumer or with the Tutorial example on this website:
Tutorial 6 - RDM; Login and event registration
If you have not tried with one of the examples or tutorials - please do so and report back the results here.
