Eikon API with R - eikonapir - Port Number
As the API capabilities have been integrated into the Eikon Toolbar, the port number being used has changed to 9000 (from 36036). Is it possible to change it in the source code? I am not too familiar with R myself, so I don't know where to do this. I am aware this is an unofficial package, but there are clients interested in it. Please note that I raised it as an issue on Github already.
The package is still looking for 36036, so I get the following error:
Error in curl::curl_fetch_memory(url, handle = handle) : Couldn't connect to server
Thanks!!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythoneikon-data-api-r
4.6k 26 7 22
Thanks Evgeny. I guess I have to rebuild the package as I don't know where to manually change it in my local package/build. Out of curiousity, why is there a letter "L" after the port number? For "listening"?
L denotes an integer in the R notation, see this.
Interesting, I didn't know that. Thanks!
Hi @Joris.Hoendervangers
A new version that uses port 9000 instead of 36036 is available in GitHub.
A set_proxy_port function has been added if you need to use another port number.
My experience has been that it didn't work until I added a line with what should have been the default:
set_proxy_port(9000L)
Thanks Olivier, I saw the activity on Github. Great stuff!
