Where do I find ExchangeCountryCodes?
I am trying to keep an eye on a variety of well performing stock. Therefore I am screening the Eikon database for stock symbols that will henceforth be judges against a predetermined set of criteria. Having the country codes enables me to find excellent companies wherever they are located.
@Joris.Hoendervangers
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythondatarics
4.6k 26 7 22
@vanderkroon we use https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 for country codes.
18k 21 12 20
You can use "SCREENER" app on Eikon Desktop to check the country code.
1. Type in "SCREENER" (without double quotes) on EIkon search bar and press enter.
2. Use filter on left side of the screen to filter out bases on your requirement.
3. Once you see the result, click on Excel icon and select "Export All as Formula".
(see picture in the reply, somehow I cannot post more picture in this comment)
4. You can see the code used in the formula.
picture for 3.
picture for 4.
