cannot receive 'PRC_TICK', cannot build order book from L2 data
Hi, team
We run some quick test, in PROD env
<UserName>svcHoHo</UserName>
<ServiceName>EED</ServiceName>
\Connections\Connection_RSSL\connectionType = "RSSL"
\Connections\Connection_RSSL\rsslPort = "14002"
\Connections\Connection_RSSL\hostName = "QAMDS72WHSSADS11"
For some RIC , we CANNOT get PRC_TICK,
for some other RIC, we CANNOT build order book from level 2 data
( Build order book from below fields Action = add/delete/update Log : INFO : MarketDataHandler : time=[2017-12-12 11:39:43.409250], sym=[ TXZ7], [Action=Add;Key=10413.0B;Px_10k=1041300000000;Key2=1041300000000,1 (BID);;ORDER_PRC=10413;ORDER_SIDE=1 (BID);ACC_SIZE=31;LV_TIM_MS=<C_BLANK>;LV_DATE=<C_BLANK>;] )
Could you check the entitlement for below RIC???
NO_PRC_TICK : CLF8/CLG8/HOF8/HOG8/JPLZ8/JRUM8/NGF18/NGF8/NGG18/NGG8/PAH8/PAM8
NO_order book :
ADH8 /ADZ7 /BOF8 /BOH8 /BPH8 /BPZ7 /CDH8 /CDZ7 /CH8 /CK8 /CLF8 /CLG8 /EDH8 /EDM8 /FCF8 /FCH8 /FVH8 /FVM8 /GCG8 /GCJ8 /HCEIF8 /HCEIZ7 /HGH8 /HGK8 /HOF8 /HOG8 /HSIF8 /HSIZ7 /JPLZ8 /JRUM8 /JYH8 /JYZ7 /LCG8 /LHG8 /NGF18 /NGF8 /NGG18 /NGG8 /PAH8 /SF8 /SFH8 /SFZ7 /SH8 /SIH8 /SIK8 /SMF8 /SMH8 /TUH8 /TYH8 /UROH8 /UROZ7 /USH8 /WH8
treprfarfa-api
7.6k 15 6 9
@quiang.zhu
For data or content relate issue please submit case using ContactUs. The content support can help you verify the data at the time you found the issue.
tested again (around 20171214_094000 EST)
NO_PRC_TICK : CLF8/CLG8/HOF8/HOG8/JPLZ8/JRUM8/NGF18/NGG18/ /PAH8/PAM8
NO_order book : ADH8 /ADZ7 /BOF8 /BOH8 /BPH8 /BPZ7 /CDH8 /CDZ7 /CH8 /CK8 /CLF8 /CLG8 /EDH8 /EDM8 /FCF8 /FCH8 /FVH8 /FVM8 /GCG8 /GCJ8 /HCEIF8 /HCEIZ7 /HGH8 /HGK8 /HOF8 /HOG8 /HSIF8 /HSIZ7 /JPLZ8 /JRUM8 /JYH8 /JYZ7 /LCG8 /LHG8 /NGF18 / /NGG18 / /PAH8 /SF8 /SFH8 /SFZ7 /SH8 /SIH8 /SIK8 /SMF8 /SMH8 /TUH8 /TYH8 /UROH8 /UROZ7 /USH8 /WH8
please advise.
