Node.js WebSocket sample does not update. (Python sample OK)
I downloaded the "streamingtools" zip file that contains the various websocket sample files and when trying out the Node.js samples, even though the app appears to successfully connect the websocket and login, after sending the initial ItemRequest there is no response from the server. No errors shown either... However, when trying out the Python samples, the server sends plenty of updates just fine. I thought maybe the sample files were bad, but when I downloaded the "Try it now" sample package, even the premade web pages had the same problem - websocket and login okay, but no updates or feedback from server.
pythontreprdp-apiwebsocketsrrtonode-js
Hi @Tokyo Nick,
Can you provide some more details? I just tried both the 'market_price.js' node example as well as the premade web pages within the "Try it now" sample package and received updates from the server. Have you installed the latest version of ADS 3.2 released on Nov 30th?
thanks.
9.7k 49 38 60
Hi @Tokyo Nick,
If you participated during the Beta phase, you may have an older version of the ADS installed. Ensure you have the official ADS 3.2 version released on Nov 30th.
Nick
Hi @nick.zincone.1
Thanks, I appreciate the quick reply!
It must be the ADS version we're running. I guess Python was supported since the Beta version.
I'll check internally. Thanks again!
Nick
