Python API error 400 for same set of data that works in Excel
Excel formula that pulls data (EPS numbers) as expected:
=TR("SCREEN(U(IN(Equity(active,public,primary))),avail(TR.EPSEstValue(Period=FY1,Brokers=US_3202),TR.EPSEstValue(Period=FY1,Brokers=US_63721),TR.EPSEstValue(Period=FY1,Brokers=US_63725))>=-100)","TR.PrimaryRIC","avail(TR.EPSEstValue(Period=FY1,Brokers={US_3202}),TR.EPSEstValue(Period=FY1,Brokers={US_63721}),TR.EPSEstValue(Period=FY1,Brokers={US_63725}))")
Python Web script API that error 400 Bad Request consistently:
df, err = ek.get_data(['SCREEN(U(IN(Equity(active,public,primary))),avail(TR.EPSEstValue(Period=FY1,Brokers=US_3202),TR.EPSEstValue(Period=FY1,Brokers=US_63721),TR.EPSEstValue(Period=FY1,Brokers=US_63725))>=-100)'], ['TR.PrimaryRIC','avail(TR.EPSEstValue(Period=FY1,Brokers={US_3202}),TR.EPSEstValue(Period=FY1,Brokers={US_63721}),TR.EPSEstValue(Period=FY1,Brokers={US_63725}))'])
I have contacted the development team and found that it returns 400 Bad Request because of timeout. The SCREEN function is complex and takes a lot of time to be processed so it can be timeout.
As I know, Equity Screener is available but not yet supported through Eikon Data API.
It looks like that the second parameter (fields) of get_data doesn't support the avail function. It works if I remove the avail function.
                      ['TR.PrimaryRIC','TR.EPSEstValue(Period=FY1,Brokers=US_3202)','TR.EPSEstValue(Period=FY1,Brokers=US_63721)','TR.EPSEstValue(Period=FY1,Brokers=US_63725)'])
However, the application needs to remove the value which is NaN.
Thanks for the help. The problem is that the following screen formula uses avail() and it works:
SCREEN(U(IN(Equity(active,public,primary))), avail(TR.EPSEstValue(Period=FY1,Brokers=US_2),TR.EPSEstValue(Period=FY1,Brokers=US_57030))>=-100,)
So I don't think avail() is the problem.
I have tested this again and found that the result is inconsistent. Sometimes, it works.
Others return "400 Bad Request".
I will contact the product team to verify the problem.
Thank you, Jirapongse. I really appreciate your help
