does anyone already succeed SymbolList posting via websocket API?
This appears to be expected behavior from the ADS when a WebSocket App Posts data with the key primitive type of Buffer. The workaround is using AsciiString as the key primitive type. With this type, the data was properly consumed/displayed by both WebSocket and RSSL consumers.
def send_symbol_list_post(ws): global post_id sl_post_json = { 'ID': 1, 'Type':'Post', 'Domain':'SymbolList', 'Key':{ 'Name': "SYM" }, 'Ack':True, 'PostID':post_id, 'PostUserInfo': { 'Address':position, # Use IP address as the Post User Address. 'UserID':os.getpid() # Use process ID as the Post User Id. }, 'Message': { 'ID': 257, 'Type':'Refresh', 'Domain':'SymbolList', 'Key':{ 'Name': "SYM", 'NameType': "Ric" }, 'Solicited': False, 'Complete' : True, 'ClearCache' : True, 'State':{ 'Stream': 'Open', 'Data': 'Ok', 'Code' : 'None' }, "Map":{ "Entries":[ { "Action":"Add", "Key":"RIC1" },{ "Action":"Add", "Key":"RIC2" }, { "Action":"Add", "Key":"RIC3" } ], "KeyType":"AsciiString", } } } ws.send(json.dumps(sl_post_json)) print("SENT:") print(json.dumps(sl_post_json, sort_keys=True, indent=2, separators=(',', ':'))) post_id += 1
Yes, I can use off-stream posting to post SymbolList to cache in ADS. You need to have a service that can accept post. The following is code in Python.
def send_symbol_list_post(ws): global post_id sl_post_json = { 'ID': 1, 'Type':'Post', 'Domain':'SymbolList', 'Key':{ 'Name': "SYM" }, 'Ack':True, 'PostID':post_id, 'PostUserInfo': { 'Address':position, # Use IP address as the Post User Address. 'UserID':os.getpid() # Use process ID as the Post User Id. }, 'Message': { 'ID': 257, 'Type':'Refresh', 'Domain':'SymbolList', 'Key':{ 'Name': "SYM", 'NameType': "Ric" }, 'Solicited': False, 'Complete' : True, 'ClearCache' : True, 'State':{ 'Stream': 'Open', 'Data': 'Ok', 'Code' : 'None' }, "Map":{ "Entries":[ { "Action":"Add", "Key":"RIC1" },{ "Action":"Add", "Key":"RIC2" }, { "Action":"Add", "Key":"RIC3" } ], "KeyType":"Buffer", } } } ws.send(json.dumps(sl_post_json)) print("SENT:") print(json.dumps(sl_post_json, sort_keys=True, indent=2, separators=(',', ':'))) post_id += 1
Thank you very much for sharing the idea. The data was posted. But when I consume the symbollist, seeing "D" for Name instead of "RIC1" (Xwindow) and other chars on putty. What am I missing?
I got the same issue when subscribing with RSSL 14002. I work fine with WebSocket API.
I will verify the problem.
