Hello @julker
To specify the username in RFA Java application which uses RSSL connection, you have to set the username programmatically. There is no configuration parameter to specify the username in RFA Java.
Please refer to Tutorial 6 - RDM; Login and event registration which explains how to encode login request message to specify the username.
