[EC]Shared memory error:Existing memory segment is only 4 seconds old. Cannot reattach for another 6 seconds.
When I execute ./start_ezd in /opt/thomsonreuters/SOFTWARE/ezd1.2/rhel6_x86_64/bin directory, I get the following message.
[scanalytics_tr@replayservice-test bin]$ sudo ./start_ezd
[scanalytics_tr@replayservice-test bin]$ ezd Version ezd1.2.F3
ezd: Initialization Failed -Check Log-
ezd Error: Initialization failed
The ezd.log says as follows.
<ServerSharedMemory: Notice: Thu Dec 07  12:26:42.013074 2017>
<END>
How should I resolve this?
elektronrefinitiv-realtimeelektron-sdk
23k 22 9 14
Likely you have EZD already running. Try checking processes that are running.
For example:
  ps -ef | grep ezd
The execution results of the command above is as below.
[scanalytics_tr@replayservice-test bin]$ ps -ef | grep ezd
scanaly+  1667     1  0 00:05 ?        00:00:00 ./ezd -c /opt/thomsonreuters/SOFTWARE/globalconfig/ezd.cnf
scanaly+  1720  1412  0 00:05 pts/0    00:00:00 grep --color=auto ezd
From the output, there is another instance of ezd with process ID 1667 running on the machine. You need to stop_ezd before starting it again.
